Instrument I/O Assistant only reading the first command
I am very, very new to LabVIEW and I am trying to program a device using ASCII codes.  When using the VI Instrument I/O Assistant only the first command is executed. So I am wondering if there is something obvious I am missing to make all the commands executed or a way to write multiple ASCII codes in one Write command?  Any help would be much appreciated. Thanks.
(3,037 Views)
We could help (most likely anyway) and yes, If you are new to LabVIEW it may be obvious to those of us that can look at what you've done so far, (think: attach your codeSmiley Sad) and know what device you are trying to communicate with. (make and model at least - best Link to the manual as we may need it as a reference Smiley Surprised
"Should be" isn't "Is" -Jay
(3,036 Views)
I am using a Stepnet Panel Amplifier, and the online manual's address is below. An example of a code I am trying to do is: .b s r0xc8 0 .b s r0xca 40000 .b s r0xcb 70000 .b s r0xcc 200000 .b s r0xcd 200000 .b s r0x24 31 .b t 1 However only the first line ".b s r0xc8 0" is being executed and the device will not move unless ".b t 1" is the first Write command. http://www.copleycontrols.com/motion/pdf/StepNet_panel_Manual.pdf
(3,026 Views)
I believe the serial interface only accepts 1 command at a time. Are you sending the CR and reading the response after each command?
(3,020 Views)
Only the first command has the response "ok" when I try to run multiple commands. If only one command can be processed at a time what is the best way to sequence commands so the device has an order it can follow?
(3,015 Views)
Nevermind, I put the commands I needed in a sequence structure and put those inside a case structure. Thanks for your help! 🙂
(2,992 Views)
Sorry, I was busy today...
Something like this might be a bit more scaleable than a sequence inside a case.
(2,986 Views)
