Instrument Drivers. Please Help!!
Here is a list of all of the instruments that I'm using in connection with LabVIEW. If anybody knows where I can get them on the web please let me know ASAP. Thanks in advance.
Datatape DTR-8
Radix 1010 Switch
Sony DIR-1000H & Adario
Sony DIR-1000M & Adario
SRL 2569 Integrator/Synthesizer
SRL 2586 Switching Units
Tektronix 3052 Digital Signal Processor
WJ 8477 Demodulator
(2,609 Views)
There are three main things you can try when searching for LabVIEW instrument drivers. First, you can contact the manufacturers of your hardware to see if they have any LabVIEW drivers available. Next, you can do a web search (I prefer www.google.com) for your instrument name with LabVIEW...an example search would be "DTR-8 LabVIEW" (without the quotes) to see if anything comes up for that particular instrument. If neither of these suggestions work, you can always develop your own instrument driver, and you can find several resources for doing this at www.ni.com/idnet.
I hope these suggestions help. Good luck with your application, and have a pleasant day.
Sincerely,
Darren N.
NI Applications Engineer
(2,609 Views)
