Installing SW CompactRIO Error 56
I want to install software on my CompactRIO (cRIO-9004), so I formatted the drive and gave it a new IP address in teh MAX explorer. By right-clicking 'Software' I can choose 'add remove software'. But after a while I get the error 56 which says that there was a timeout communicating with the RT target.
I use LabVIEW 8.5. Earlyer with LabVIEW 8.2.1 I could install new software on the very same CompactRIO. In the meantime we had a lot changes in the IT environment in our company. Could there also be a problem with the firewall? My firewall is turned off and there it says that my administrator is using Group Policy to control the settings. Whatever that means...
Has anybody a tip?
Dave
(2,854 Views)
Hi Dave,
take a look at this knowledgebase:
http://digital.ni.com/public.nsf/allkb/922DDC440FCB15048625719D006FCB97?OpenDocument
Hope this helps
best regards
Dippi
(2,833 Views)
