Installing LabVIEW on a TPC-2230
Recently for a project, a TPC-2230 was purchased to control my DAQ system. How do I install LabVIEW onto it and what versions are comparable with it? At the same time, how can I save a file as an older version so it is comparable on the older versions of LabVIEW.
(1,722 Views)
Accepted by topic author bfrise
As far as I can tell, the TPC-2230 runs Windows 7 Embedded.  The last version of LabVIEW to support Windows 7 was 2020 SP1, per this page.
Any "File" menu in LabVIEW should have a "Save for previous version" option.  You can save one file at a time by doing it from a VI menu, or the contents of a library or project by doing it from the menus for those instead.
(1,705 Views)
that worked perfect. For a weird reason, the browser on the HMI wasn't giving me any options to install it, so I had to use my computer to get the installation files for it. But so far, it works. Thank you for your help
(1,623 Views)
