Installing LabVIEW 8.2.1 with DAQmx 8.0 on Suse 10.2 for Linux.
We recently installed LabVIEW 8.2.1 on Opensuse 10.2 for Linux.  After some work, my advisor was successful at getting the install to work with DAQmx 8.0 and NIKAL 1.5.  I thought I would post the install notes for anyone who finds them useful.  Everything seems functional thus far.
Jeff Hay
(3,881 Views)
Awesome post, thanks!
David Staab, CLA
Staff Systems Engineer
(3,857 Views)
Great info. Thanks for posting this!
Wiebe.
(3,841 Views)
Thank you for posting the info!
Yi Y.
http://www.ni.com/support
(3,811 Views)
Jeff,
Thanks for the extremely detailed post.  I have actually been experimenting with this combination of software for the past couple weeks (i.e. OpenSUSE 10.2, DAQmx, LabVIEW 8.2.1).  Your steps match mine very closely.  I did have a one thing to add, and one question about your steps.  First, I just want to mention that NI-KAL 1.6 has been released and it fixes several issues when installing NI-KAL with newer kernels.  This is available at:
http://joule.ni.com/nidu/cds/view/p/id/850/lang/en
I would highly recommend using NI-KAL 1.6.
Second,  I wanted to ask about step #2 where you modify the modpost.c file.  When I ran updateNIDrivers I was not required to make this change.  However I did have to increase the allowable symbol length.  I changed the line:
#define SZ 500
to
#define SZ 1024
in modpost.c.
I then proceeded to follow the steps you mentioned and was able to run updateNIDrivers without error.  Could you test to see if changing the allowable symbol length fixed the problem without having to ignore the "parse error in symbol dump file."  I don't exactly know what the read_dump function does but it always makes me nervous to ignore errors.  Since NI-KAL uses modpost to install a kernel module, this failure may be important, although I don't know for sure.
Once again thanks for your awesome post.
Neil S.
Product Support Engineer
Multifunction Data Acquisition
(3,786 Views)
