Installer
Hey guys,
i want to create an NI Installer from my Project. It should also install "Additional INstallers" -> LV RT 2011 SP1 + NI VISA 5.4
When I do this and start the installer it does everything really quick. When i start the exe it says I need the LV RT 8.2.1 but I dont know why... Also it is not installing the LV RT 2011 SP1 or the LV RT 8.2.1 into the System when I say that they should be installed as "Additional Installers".
NI VISA 5.4 is already on the tes pc so ignore that...
Exe Startup
And NI Components that are installed on the system
Selected within my MainInstaller (Plus NI VISA 5.4 at the end..)
CLA
(3,381 Views)
Silly question:  Did you restart the target to finish the installation?
"Should be" isn't "Is" -Jay
(3,365 Views)
Hello KT_Boing,
your installer (.exe) should be >100 MB. If this is not the case, the installer probably doesn't contain the RT's.
Could you please check if the path of the "Installer source location" is valid?
Best Regards
Felix
(3,309 Views)
