Installer "Source file settings", "VI Settings" problem in 8.2
I have just upgraded from LabVIEW 8.0 to 8.2 and it seems the Installer "Source file settings", "VI Settings" check boxes no longer have any affect on the built application.
For example, if I un-check the "Show Menu Bar" boxes for my Main.vi and build, when I run the built application the Main.vi Menu Bar is visible.
It seemed to work as expected with 8.0 though.
Any help and suggestions are much appreciated.
Aaron
(3,533 Views)
Hi Aaron,
I have noticed this too.  I have reported this to NI R&D and they are currently working on it.  For now, I guess as a work around is to change these settings in VI Properties Window.  Then when you build the exe the menu bar will not be there.
I will inform you when this is fixed.
Seamus
NIUK
(3,515 Views)
Hi Seamus,
Thanks for that and I look forward to hearing from you again
Aaron
(3,507 Views)
