Installer error message
Hi there,
I have a problem regarding an installer build using LV 2009.
The error occurs when I run the setup.exe and here is the screenshot: error.png
The error comes when I try to add some files to my installer. I have an application using some plugins located in llbs.
So I have to copy a folder containig these llbs in my application directory, and this causes the installer to crash.
Do you have any idea? Or is there another possibility to make the installer copy this folder?
Thanks in advance for you help.
Regards
(2,942 Views)
Hello toto26,
Thanks for posting on National Instruments forum.
Some National Instruments installers require the existence of a 'My Documents' and/or a 'My Pictures' folders. If these folders do not exist the installation will fail.  This error can also happen if your 'My Documents' or 'My Pictures' folders are on a network location which is not accessible at installer runtime.
You will find the information on this link.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(2,909 Views)
