Installer build issue LV2010
Hello All,
After installing DAQmx 9.8 with my LV2010 installation I can no longer build an installer, I can however build an executable.  I removed LV2010 but not everything unfortunatly and reinstalled LV2010 with original device drivers distrubution DVD on my PXI-1042Q with a PXI-8106 Win7 64bit controller and still get the identical "Build Errors" message:
I loaded the _edit.log file and searched for "Edit code -30" and there is not and error in the log as per instructions from this link:
http://digital.ni.com/public.nsf/websearch/8E5E6C58C625B88A8625786A005B21E0?OpenDocument
Any ideas?  PLEASE SEE ERROR LOG BELOW
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> AB_UI_FRAMEWORK.vi >> AB_UI_Frmwk_Installer.lvclass:Build.vi >> Installer.lvclass:Build_from_Wizard.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_InitializeDistribution.vi >> NI_MDF.lvlib:MDFConfig_SetDistributionLanguage.vi
Loading product deployment information
*** Error: Improper function call or command line argument. (Error code -30)
*** Error Details:
Error in MDF API function: _MDFConfig_SetDistributionLanguage
The MDF does not have support for distribution language LANGID 9.
*** End Error Report
(2,611 Views)
It sounds like you re-installed LabVIEW 2010 after DAQmx was installed on your computer. This can cause errors.
You may want to make sure you install DAQmx drivers after your LabVIEW 2010. (Re-install DAQmx)
(2,578 Views)
It is most likely that I will need to edit the registry to solve this problem since as I mentioned in my original email I uninstalled LV and reinstalled it with the original DVDs.
(2,570 Views)
