Installer Suite
Hi I have made an application which is currently in the form of a library (.llb) I want to include some non Labview Files with it which are necessary for the application to run. I was wondering if there was a way I could make an executable and also make an installation utility that will copy all the files to a specific location. My question has 2 parts
1. how to make executables in Labview
2. How to make an installation suite. Other than using Winzip or something like that.
I have the full development version of Labview 6.1
(2,883 Views)
You need the 'Application Builder' addon for labview, it will do everything
you need.
Mike Sachs
Intelligent Systems
"shabu" wrote in message
news:506500000008000000914F0000-1023576873000@exchange.ni.com...
> parts
6.1
> Thanks
(2,883 Views)
The LabVIEW Application Builder is definitely what you will want to use. You can use this utility to build an executable and distribute it to other computers. The Application Builder ships with the LabVIEW Professional Development System, but it may be purchased separately if you own the LabVIEW Base Package or the LabVIEW Full Development System.
I am attaching a pdf file which addresses common questions about the LabVIEW Application Builder.
J.R. Allen
(2,883 Views)
