Installer: Cannot write registry key which data begins with #
Hi all,
It seems to be impossible to install a registry key which data begins with the # sign.
Is there a workaround available for that like \# in C++?
BR,
Jonas
(2,459 Views)
Hi Jonas,
Which VI are you using? I tried to implement the example VI "Windows Registry Manipulation.vi" from LabVIEW2013. I changed the String Value from "LabVIEW" to "#LabVIEW" and it seems to work.
The used VI and result screenshot are attached to this message.
Marc
(2,418 Views)
