Installation of SignalExpress with Windows7 32Bit doesn't work
I have LabView SignalExpress 3.0 and a Notebook 32 Bit with Windows 7.
After few seconds after starting setup.exe from DVD  the following message appears:
Structured Exception number 0xC0000005
Exception Report:Exception code: C0000005 (ACCESS_VIOLATION)Fault address:  003B275A 0001:0001175A C:\Users\larlan\AppData\Local\Temp\niiC811.tmp
Registers:EAX:00000000EBX:00000000ECX:0356CBACEDX:002A69A0ESI:0356CBACEDI:00000190CS:EIP:001B003B275ASS:ESP:00230356CB68 EBP:0356CBE8DS:0023 ES:0023 FS:003B GS:0000Flags:00010246
Stack TraceAddress  Frame    LogicalAddr    Module    SymbolName + Offset003B275A 0356CBE8 0001:0001175A C:\Users\larlan\AppData\Local\Temp\niiC811.tmp DllUnregisterServer + 4250003A3D7E 0356D0D8 0001:00002D7E C:\Users\larlan\AppData\Local\Temp\niiC811.tmp 003A478D 0356D43C 0001:0000378D C:\Users\larlan\AppData\Local\Temp\niiC811.tmp 003A4DA9 0356D934 0001:00003DA9 C:\Users\larlan\AppData\Local\Temp\niiC811.tmp 003A5613 0356DCB4 0001:00004613 C:\Users\larlan\AppData\Local\Temp\niiC811.tmp 003B17E4 0356E2DC 0001:000107E4 C:\Users\larlan\AppData\Local\Temp\niiC811.tmp DllUnregisterServer + 292004949C1 0356E7FC 0001:000939C1 S:\setup.exe 0046B97A 0356F784 0001:0006A97A S:\setup.exe 0046DDDE 0356F864 0001:0006CDDE S:\setup.exe 77B56570 0356F868 0001:00055570 C:\Windows\SYSTEM32\ntdll.dll wcsnicmp + 318877B565A6 0356F888 0001:000555A6 C:\Windows\SYSTEM32\ntdll.dll wcsnicmp + 32427780DB00 0356F8D8 0001:0003CB00 C:\Windows\system32\kernel32.dll BaseDllReadWriteIniFile + 341377B56570 0356F8DC 0001:00055570 C:\Windows\SYSTEM32\ntdll.dll wcsnicmp + 318877B565A6 0356F8FC 0001:000555A6 C:\Windows\SYSTEM32\ntdll.dll wcsnicmp + 32427780CECE 0356FA08 0001:0003BECE C:\Windows\system32\kernel32.dll BaseDllReadWriteIniFile + 291004F00E6 0356FA44 0001:000EF0E6 S:\setup.exe 00429E5A 0356FABC 0001:00028E5A S:\setup.exe
Has anyone an idea what I could do?
Thank you in advance.
Andreas
(2,783 Views)
Hi Andreas,
I´m sorry, but the installation of SignalExpress 3.0 on Win 7 is not supported.
http://joule.ni.com/nidu/cds/view/p/id/1143/lang/de
Best regards
Andrea P.
(2,767 Views)
The problem was that SignalExpress 3.0 has been already installed before. But uninstalling has not been done properly. This causes the error described above. A way to solve the problem was to clean registry with msiBlast.exe. Reinstallion has been done successfully then.
Andreas
(2,763 Views)
Hi Andrea,
Thank you for your answer. With Windows7 32Bit version it works indeed.
Andreas
(2,759 Views)
