Installation Labview 2014
Bonjour à tous,
Je viens de télécharger et d'installer Labview 2014 64bits, l'installation s'est correctement déroulée, mais à la fin du setup, le programme d'installation recherchait un fichier ou dossier qui s'appelle "device helper". J'avais la possibilité de sauter cette étape durant l'installation, donc je l'ai fais. Pourriez vous m'indiquer ou pourrais télécharger ce fichier pour compléter l'installation s'il vous plait.
En vous remerciant d'avance pour tout,
Alexandre,
(3,501 Views)
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:4.9547.9548,ssnav:...
Or just download the specific driver for the type of device you are planning on using such as DAQmx. You should also know that 64 bit LabVIEW does not have full support for all drivers/toolkits.
(3,483 Views)
I've always hit "Decline Support" and never had any issues.  Honestly, I have no idea what that's actually supposed to be installing.  Any support you need can be downloaded like Dennis pointed out.
You should also look at: https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
It will help you determine if you really want to use 64-bit instead of 32-bit.
(3,465 Views)
  • Not everyone on the forums speaks English.  If English is not your native language feel free to post questions in your first language, but be aware that there are several non-English speaking sub-forums.  If you post a non-English question in the English forum, you may or may not get people who speak your language. Stick to forum for that language to ensure you get the help you need.
Source
(3,404 Views)
