Install Report Generation to LV7
I would like to add LV Report Generation SW for MS Office to my LV7 installation. I already have it installed for my LV6.1 installation and I need to keep all my old versions of LV for customer support. My Report Generation CD is 1.0.1.
(2,792 Views)
The report generation toolkit must be manually installed to a second install of LabVIEW. You can either follow the directions here or use the attached tool I made to do it automatically. You should just need to open it in 6.1 (or whatever you have the toolkit currently installed in) and run it. It will find your other LabVIEW installs and copy all the required files.
There is also a patch for the toolkit that NI released to fix some bugs that came up in 7.0. You can download the patch on this page.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,792 Views)
