Install MAX with only LabVIEW runtime engine
I want to know if it is possible to install MAX from the Device Driver CD, when only LabVIEW RunTime engine is installed.  There is no full installation of LabVIEW on that PC.  That's MAX 3.1.1.3004 with LabVIEW RunTime Engine 7.1.
Patrick.
(3,413 Views)
Dear Patrick,
The device driver CD usually does not have a single installation of MAX, but you can install MAX by installing most of the other drivers such as NI-DAQ, NI-488.2, NI-Serial, etc. MAX does not require LabVIEW, so you can have MAX and LabVIEW Run-Time without LabVIEW. Have a great day!
Sincerely,
Marni S.
(3,388 Views)
