Inserting commands in to system exec vi
I want to insert multiple commands in  the same cmd window. I use system exec vi but  i don't manage to get it work.
So, I have 10 command to be inserted in my cmd windows and for first I insert  5 command and after I receive a  trrigger from an external device (It could be last 5 or 10 seconds or more),  the remained  commands need to be inserted in the  same cmd window.
Attached you will find  how I aborded  the problem so far, maybe somebody can help me.
Vlad
(3,720 Views)
Put them in a batch file and then call the batch file with the systemexec.
=== Engineer Ambiguously ===
(3,711 Views)
It wont help me, because i dont need to send all the commands at same time in the same cmd window.
As I said in the first post, I need to send in the first instance a number of commands and after a specific time (waiting for a trigger) another commands in the same cmd window.
Thank you.
(3,699 Views)
A batch file can do that and it is really the only way you are going to be able to use the same systemexec window for multiple commands.
(3,696 Views)
