Inserting an image into a Word Table with the Report Generation Toolkit.
I was wondering if it was possibe to use the Report Generation Toolkit to place an image into the cell of a table in a Word document?
"All truths are easy to understand once they are discovered; the point is to discover them." -- Galileo Galilei
(3,351 Views)
Accepted by topic author B.Settles
Yes, you can do this by using the Word Edit Cell VI under Report Generation>>Word Specific>>Word Tables in your block diagram functions pallette.  After creating a table, you can edit specific cells and send the file path of the image saved on your computer to that specific cell.  I put together an example that I've attached here as well to help you out with this.
Austin S.
Academic Field Engineer
(3,309 Views)
