Inserting an image in a column of a multicolumn listbox
ToNi,
Apparently, you didn't noticed that I changed the image display for an array of pictures, instead of an array of pict rings. The original pict ring array is still there, but is outside the front panel window. As I said, I just use it as a source for the icon images.
I noticed also the second version I attached in my last post seems to be somewhat corrupted (1 kb ???), although
your vi seems to be a mix of my first and second versions.
Just in case, I attach again the second version, with some comments added on the diagram, since it contains most of the answers to your questions.
Chilly Charly    (aka CC)
Message 11 of 13
(1,384 Views)
Thanks chilly, it is just I need but only three last questions about it... I would like to have an array of picts ring so the user can modify the picture displayed for another one in run time, is it possible? and is there anyway to know the index of the item in the picture array the user has selected? and finally... can I have several picture arrays (one for each column of my multicolumn listbox)?
Thanks for helping me 😉
ToNi.
Message 12 of 13
(1,204 Views)
I have added a button to change the image after selecting the row to be affected. I suppose that this modification is an answer to your questions 1 and 2, since to be able to modify a row you have to know which one was selected ! 😉
I think also that adding another picture array to have a second picture column will not be a too difficult task for you 🙂
CC
Message 13 of 13
(1,195 Views)
