04-25-2006 07:31 AM - edited 04-25-2006 07:31 AM
Message Edited by PatchProgram on 04-25-2006 07:35 AM
04-25-2006 09:29 AM
10-18-2010 07:55 AM
This is exactly what I want to do.
I have a pointer slide and I want to add or remove a pair of sliders by clicking a add- or remove-button.
I placed the slide on the front panel, added several sliders to this slide and created a property node of the slide. Now I don't find a property to make one slider invisible. I can only make the whole slide invisible.... 😞
How can I make a slider (not the slide) invisible?
10-18-2010 08:56 AM
You can change the fill color to be transparent.
10-18-2010 10:16 AM - edited 10-18-2010 10:24 AM
I stil have no clue...
Doesn't refer the fill colour property to all sliders?
What color number is transparent?
Attached some pictures:
1. a clueless try
2. the slider properties
3. the slider
10-18-2010 11:01 AM
The value for transparent is 16777216. In LabVIEW 8.2 I have the "color box constant" for this value.
Regards, Vt133
10-18-2010 11:49 AM - edited 10-18-2010 11:50 AM
johanneshoer wrote:Doesn't refer the fill colour property to all sliders?
To change the color of a particular slider, use a property node with two entries:
