Insert into String
I'm trying to insert some value into a string but I can't figure out how to do this. For example a string might be 32323030 but I want to make it 32322E3030. How can I do this?
Please take a look at the attached VI. (LV 8.2)
(8,405 Views)
Take a look at this VI I made.
Cheers.
Ali
(8,389 Views)
There are many here who can answer the question that you directly asked... But in looking at your vi, I am puzzled at what you are actually trying to do.
For instance, where does the dbl come from?  The name indicates you are trying to convert to hex?  But I do not understand by looking at your VI where you are starting, and where you are trying to get to.
Paul
(8,387 Views)
Thanks Ali that works great.
Stradis:
You didn't need to know any of this for the original question but since you asked.....
The string will feed into a Temp controller using RS232. The user will enter a setpoint temperature, which will be the input, and the VI will generate the correct format of string needed. I put the input into hex because as a checksum the controller requires an XOR of the string to also be sent.
(8,370 Views)
