Insert equation to MS Word form string control
Hi!
I would like to use MS Word equation function.
So I have a string control, set text i.e. "E= mc^2", (when I use tags in MS Word, select text ->equation function -> Professional, the result is a format what I excepted.) my question is how to do this automatically from labview?
So, if I set any tags to String control, the text converted to equation (->professional) and the result can be seen in ms word doc?
Thank you!
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,705 Views)
You have to use ActiveX in order to program MS Word from an external program. This KB article talks about ActiveX and LabVIEW in general. There's also a chapter in the LabVIEW Help. Beyond that you need to look at the MS Word automation documentation to find out what properties/commands to use to insert an equation.
(2,695 Views)
