Insert data to new row in csv Excel file
I have created a subVI that writes 2 1D array( 1st: header, 2nd: data) to a csv Excel file using Write to Spreadsheet File. However every time it runs, it overwrites the old data.
But I want the new data to be written on the next row instead of the old data being overwritten. How do I do that?
(5,779 Views)
Every time you call that subVI, you overwrite the previous data with the header information (the first Export to Spreadsheet file) and then append a line of data (the second). You only want to write the header once, and append data multiple times.
You could either split this into two subVIs (one for file generation and header writing, another for appending) or, more preferably, use a state machine with initialise and write states that do the same thing.
Edit - also, Write to Spreadsheet File accepts only arrays of data, so there's no point bundling the inputs into a cluster, unbundling and then building an array of them.
CLA
(5,772 Views)
i would use 'check if file/folder exist' and a case statement...if false(write header), if true(just pass the file path through)
(5,758 Views)
And lets not forget about the Rube pointed out by the user thoult here.
As Christian Altenbach would say: "Do more with less code in less time" 🙂
Regards
Mondoni
(5,737 Views)
Regards
yeah... it was around midnight here when i posted, i looked at it and and and..................................im going to bed!
(5,724 Views)
