Input value range selection (Extract portion of Signal)
Hi Guys,
Im trying to select a value range from a signal. i can fix the starting point value which is -0.2 but i coudnt set the ending value range which is 0.2.
I only managed to set the length in number of sample but not in unit value. Is there any way so set the range portion from -0.2 to 0.2?
Here, i also attached the vi and data file. (Run, dont use Run Continously)
Yunus
(3,277 Views)
Accepted by topic author Nusnus
Hi Nus²,
no need for ExpressVIs for such a simple task:
Now you can access the X data array easily and use array functions (like Threshold1DArray) to find the indexes of your desired range in the array. You will do this twice: first from the start, then from the end. With those two indices found you can easily create subsets of your array data - well, the needed function is named ArraySubset…
Btw. not everybody here is able to use 7zip so you better attach VIs either directly as VI or use standard ZIP format!
(3,221 Views)
Thank You. You really helped me here.
(3,178 Views)
