Input items to a ComboBox at runtime
Hi
I'm trying to use a comboBox to display a list of item only at runtime. For example, there are 2 combo boxes, the first one is a menu (1-4), when option 1 is selected at runtime, the second combo box should have a list for option 1 which might be (A-D). It this possible in LabView 8?
Message 1 of 14
(4,854 Views)
Sorry it's in LV 7.1.1, but it should work in LV 8 also 😉
Epictetus
Antoine Chalons
Message 2 of 14
(4,837 Views)
Please see attached for your reference.
In addition, you may consider using
  1. Enum or
  2. Menu Ring
to achieve your requirement 😉
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 3 of 14
(4,836 Views)
Cool, i tried both solutions. I'm deploying it to a PDA, so the same rules should apply right?
Message 4 of 14
(4,830 Views)
might i'll try both solutions. Thanks for the quick response
Message 5 of 14
(4,829 Views)
I forgot to mention that it is for a PDA, so property node is not supported.
Any other ideas?
Plus, the String ComboBox has a very small drop down button that the size can not be increased and it can't be see on a PDA, a Ring drop down will be prepared.
Message 6 of 14
(4,821 Views)
Well the code is not different to do the same with a dropdown box instead of the combo.
I have never used LV on a PDA and didn't know that property nodes are not supported Smiley Surprised.... an then I don't know how to do that... Smiley Indifferent
Sorry...
Epictetus
Antoine Chalons
Message 7 of 14
(4,818 Views)
In LV PDA 7.1 there is a function in the Application palette: PDA Set Ring Strings.vi. It needs a reference to the ring control as input.
However, there were many changes from 7 to 8, so I don't know if it's still there.
Paolo
Paolo
Message 8 of 14
(4,811 Views)
Hi
The PDA Set Ring Strings.vi is still available on the Applications Palettein LabVIEW 8 for your reference.
Regards
JamesC
NIUK and Ireland
Message 9 of 14
(4,781 Views)
Thanks, just trying to get my head around it now.
Message 10 of 14
(4,777 Views)
