Input String and Number block
This is embarrassing.  I was just in a NI LabView presentation and they had an example VI that used a VI function that accepts a string and parses it based off of a token string.
So the example was…
If you had an input string of…
Value = 3
… and fed the VI function a token string of…
%s = %n
… the returned values from the block are a string and a numeric, “Value” and 3 respectfully.
Does anyone know where this VI function block is in the palates?
Thanks.
(4,555 Views)
Look for SCAN FROM STRING - row 2, column 0 in the STRING function palette.
Except the "%n" won't work.  If you're looking for a decimal number, use "%d".  Consult the help for other options.
Message Edited by CoastalMaineBird on 07-09-2009 03:34 PM
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(4,550 Views)
Hi Phillip,
"scan from string" in the string functions palette...
(4,548 Views)
Accepted by topic author PhilipJoeP
Scan From String (in the String palette).
EDIT: Guess everybody must be on a coffee break. Smiley Very Happy
Message Edited by smercurio_fc on 07-09-2009 03:34 PM
(4,545 Views)
