Initilize a control to visible/not visible.
I'm using the property node to make controls visible/not visible based on which options I want avaliable to the user. I can't seem to find an option
that will allow me to initilze the control to a default state (either visible or not visible). I'm using a startup step to set all controls to the correct
state, however; this seems like an ugly solution because I have a string of 20+ property nodes and takes up lots of block diagram space.
(2,313 Views)
Hi bo,
set the control to "hidden" by right-clicking the terminal in the block diagram. Then save the VI. Now those controls are not visible by default...
(2,306 Views)
