Initializes an array and passes as a pointer causes labview to crash
Ah okay that makes a lot of sense. If only the wizard did perform magic! Luckily for me, that is the only function that would require this. I am getting an error saying: One or more required inputs to this function are not wired or are wired incorrectly. Do all the inputs need to be wired to something, even if they are a pointer?
Right now the inputs that are not wired are:
uint32_t* timeDomainFramesRead
uint32_t* frequencyDomainFramesRead
Message 11 of 14
(1,043 Views)
That are most likely 32 bit integers passed as pointer. So have you configured them as
Control Type: Numeric
Data Type: 32 bit signed integet
Passed: as pointer
You can wire a 0 constant on the left side of the node to these two parameters and on the right side you get the number of actually filled in elements in the according array.
Rolf Kalbermatter  My Blog
Message 12 of 14
(1,010 Views)
That is what I was thinking. It is nice to know how memory can actually be allocated in labview. I am trying to graph the output of timeDomainBuffer which will be an array of signed integers. The array will be segmented by a block size. For example, if I set my block size to be 1024 and input a 4k Hz signal, timeDomainBuffer's output should be multiple sine waves where array[0...1023], array[1024...2048]... are each a sine wave.
I am unsure what would be the best way to graph this.
Message 13 of 14
(983 Views)
I figured it out. If I use array subset I can pick what I want from the array.
Message 14 of 14
(965 Views)
