Initialize the Smoothing Filter
I'm using the "Filter" vi off the Waveform Conditioning Palette to smooth some data being collected from a fairly noisy sensor. I use it in a program that plots the Frequency Response of electromechanical actuator, and if I run it a second time with a new data set, the measurement gets distorted as if the filter isn't getting initialized, but if I stop the program and restart it works perfectly.
The vi doesn't offer any option to "initialize" it, and I if I try to build the function discretely, I get vastly different results.
Any suggestions on how I can initialize it without restarting the program?
Message 1 of 10
(1,809 Views)
Let us see some code!
Generally,  filter VIs do have a "reset? Input that is an "Optional" terminal default to False.  Those Optional terminals are not normally shown in the context help window!  There is a tiny icon on the lower left of the context help window that toggles the view of Optional input terminals!  😀
"Should be" isn't "Is" -Jay
Message 2 of 10
(1,781 Views)
It's an Express vi, there are no additional "Optional" terminals.
Message 3 of 10
(1,764 Views)
Accepted by topic author ScottR22
Hi Scott,
So the simple solution is: don't use the ExpressVI, but use the filter functions in the signal processing palette…
Message 4 of 10
(1,761 Views)
Agree, but as I stated when I try to implement a moving average filter, I get very different results, and i would like to know what exactly is being done under the hood of this "canned" vi to make that the case?
Message 5 of 10
(1,754 Views)
I found my mistake, this solution works.
Message 6 of 10
(1,748 Views)
Hi Scott,
another option to implement a moving average:
Message 7 of 10
(1,738 Views)
That's actually the way I first tried to implement the moving filter, but I didn't have the for loop, I just sent blocks of the waveform data into the mean function as an array, the problem is it decimated the waveform so and I forgot to update my X-Axis accordingly. Using the discrete functions you suggested from the Signal Processing palette produced the exact same results as the Express vi without the Initialization issue, so theres a bug in the Express vi for sure.
Thanks for you assistance.
Message 8 of 10
(1,732 Views)
Hi Scott,
@ScottR22 wrote:
That's actually the way I first tried to implement the moving filter, but I didn't have the for loop, I just sent blocks of the waveform data into the mean function as an array, the problem is it decimated the waveform…
That's why I depicted the Pt-By-Pt_Mean function: it doesn't decimate the incoming data…
Message 9 of 10
(1,727 Views)
Appreciate it.
Message 10 of 10
(1,723 Views)
