Initialize myRIO with LINX.
Hi, everyone!
I'm trying to make a myRIO project using LINX for the code. My problem is that I don't know how to
read or initialize the device using LINX.
If you can explain to me how can I do it, or show me a VI example where you use the LINX code with myRIO, I'd be grateful.
Thanks advance!
(3,782 Views)
Galeano, I found this forum from the LabVIEW MakerHub community that can be useful for you: LINX for NI myRIO-1900
Apparently, the best place to start is enabling the myRIO support for the toolkit in LabVIEW: Tools»LabVIEW Hacker»LINX»myRIO Support.
All the best,
(3,737 Views)
Hey Oscar,
Thanks for the response!
I've already saw that forum, and I did the "enable myRIO support" and so. My problema is now in the select channel for "Check channel" tool. I don't know exactly what channel it's asking me for and how I could configure it.
(3,672 Views)
Accepted by topic author Galeano
Here I found a solution to read the device myRIO.
The code was made to read the MPU sensor parameter using myRIO, and LINX code.
Thank you anyway, Oscar!
(3,649 Views)
