Initialize and Index real time data into 2D array
Hi N.,
1 - Where are any "columns disabled"? I don't know what you are talking about…
2 - "Intensity graph 3" should show the same as "Intensity graph". I don't know what you have problems with…
please check the attachment.
As it's just an image there is nothing to "check". Attach your VI (LV2014 preferred)!
Message 11 of 18
(1,714 Views)
Good Morning GerdW,
please check my attachment.
in the index array, i can't specify the column, only rows.
intensity graph 3. display my data only once, even i'm read from VISA
Thank you
Message 12 of 18
(1,709 Views)
Hi N.,
As soon as a I wire the column input (instead of the rows input) I can index columns…
(Btw. why don't you use TransposeArray? Or even simpler: tick the Transpose option in the graph properties…)
IntensityGraph3 displays the data present in "Array" and "IntensityGraph"…
The shift register used for "IntensityGraph2" is non-sense as it never gets updated data…
Message 13 of 18
(1,699 Views)
Dear GerdW,
hence, now i started looking to your name everytime to make sure that it's correct.
however, my idea is keep the scal of the graph 3 is fixed. if i ticked the transpose click that will make it automatic and change it's scal.
also i'm trying to find a way to display both columns and rows at the same time, wich allow me to detect the resolution in accurate way and display the force over my connected mat as pressure depends on the colours.
any advice ?
Message 14 of 18
(1,697 Views)
Hi N.,
Why should transposing a 2D array change your scale settings?
An intensity graph displays 2D data, so you can see all rows and columns at the same time!
I don't get your problem…
Message 15 of 18
(1,693 Views)
It's my bad.
i connected rows and columns and this case he started to be autoscale.
but if i connected only rows to the index which is from 0 to 3. (4 rows)
the graph display only once, i need to display all the time (read all the data from visa until i stop the program).
i know i'm nagging a lot, i'm sorry, but i'm learning from your advices / forgive me
Message 16 of 18
(1,694 Views)
Hi GerdW,
a quick question please,
why my  index array doesn't update the intensity graph3 after the 4th count.
the program runs perfectly but this intensity graph won't update with real time.
what should I do to make it display the data in real time. not only one round ?
the attachment contain a picture of the problem and VI
Message 17 of 18
(1,676 Views)
Hi N.,
Because YOU have it programmed this way…
You explicitely only index the first 4 rows to display them in the graph. When you want more/other rows you need to index them!
As said before: wire the full array to the graph, not just 4 indexed rows/columns…
Message 18 of 18
(1,667 Views)
