Initial order of parallel loop
I have two parallel loops.  One of them must start first for one iteration.  After the first iteration, order of perference between the loops no longer matter.  I used notifier inside a case structure that gets activated only when i = 0.  Is there a better way?  If I want to do this with semaphore, how would I do that?  Thanks!
(3,516 Views)
Hi jyang72211,
i think semaphore is not the one you need. You should think about a rendezvous.
If you need the notifier also for other communication between these two loops, then i would use this solution.
Mike
Message Edited by MikeS81 on 02-26-2009 02:43 PM
(3,510 Views)
Thank you!
(3,478 Views)
Does the first loop have to complete its first loop before the second one starts, or does the first loop just have to start executing before the second one? If the later, you could also put a short delay in front of the loop you want to start second. This would guarantee that the other loop would always start first.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,461 Views)
The first loop must complete 1 iteration between the second loop starts.  On a side note, when you said I can put a delay in the loop I would like to start later, does that have to be a time loop?  If not, how can we can sure that the program will not touch anything in that code before the time delay expired?
(3,457 Views)
Actually what I said was put a delay before the loop that needs to start second. Also you would need to be sure to wire an output from the delay to the border of the loop to establish a data dependency.
Mike...
LabVIEW Champion
(3,448 Views)
I never thought of it this way.  Thanks!
(3,429 Views)
