Indicator update issue
I have used a boolean indicator in a VI which is O/P of that VI. Value of that boolean variable is being update in the block diagram of the VI and I am expecting that the same value is available to O/P terminal. But I am unable to see the value in front panel and at O/P of VI. This is something very strange to me.
Note: I made sure that it is not getting overwritten by any means.
Is there any setting which may cause this? Pl help
Thanks in advance
Manish
(2,634 Views)
Use probe to check whether data is passed to the terminal.can you post your vi. so that it will be more clear.
(2,632 Views)
