Indicating cycle
I really have no idea how to put this into a labview program but I can put it into words...
I have an array and when that array is indexed, I want an Led to light up on the front panel. Like so in the image attatched.
Thanks and sorry if this is a really silly question!
Message 1 of 9
(4,311 Views)
You will want to store the array in a shift register.  When you index the array, you will need to take the value you indexed, change the LED to TRUE, and then use Replace Array Subset to replace the indexed value in the array, which will then display the LED as a TRUE value.
Message 2 of 9
(4,291 Views)
How do I shift only one part of the array? The other parts do not need to be shifted.
Message 3 of 9
(4,273 Views)
A shift register does not shift anything.... 😉
Message 4 of 9
(4,267 Views)
Do I need to unbundle it first then? Im just trying to access a boolean.
Message 5 of 9
(4,263 Views)
You can use the "in place element structure" to modify cluster elements. Please attach some simplified version of your code. It is much easier to demonstrate things
Message 6 of 9
(4,259 Views)
This is my block diagram
Message 7 of 9
(4,251 Views)
No, that's just an image.
Message 8 of 9
(4,236 Views)
Hi Adam_Keller,
This is just a very simple example that may clear your ideas just a little.
Hope it helps.
Regards.
Message 9 of 9
(4,233 Views)
