Indexing help
Hello
I am looking for a quick way of indexing in groups. That is for example I have an array of 100 elements and I want to index it as follows.
I want to create two groups.
First group: 1,2,3,4,9,10,11,12,17,18,19,20,25,26,27,28,....
Second Group, 5,6,7,8,13,14,15,16,21,22,23,24,29,30,31,32
note: number is the index in the 100 element array
So that would be 2 groups of 50 each but indexed as it follows. I am not sure if there is a quick way of doing this through for loops.
Thank you
(3,627 Views)
Accepted by topic author seb1509
There are many ways to do this. In newer LabVIEW versions, you have the conditional tunnel, so that would give a simple solution, e.g. as follows:
(3,620 Views)
@seb1509 wrote:
Hello
Thank you
I don't think you'd get 2 groups of 50.  100 is not divisible by 8.  Because of your 4 ON, 4 Off pattern, your first group will have 52 numbers, your second will have 48.
(3,605 Views)
Another variation using Reshape Array and conditional concatenating tunnels.
(3,594 Views)
That only works if there is no remainder for the division, else the last elements will get truncated. My solution maintains the pattern irrespective of input size and will create unequal output sizes if needed. Probably a more universal solution. 😄
(3,587 Views)
