Incremental reading of large TDMS files using npTDMS
We are acquiring data from multiple hardware components and streaming to TDMS. Typically we are acquiring at ~ 100 Mb / s so things get big quickly. So far we can incrementally read in data using Labview and Matlab. So we can read in frame n and loop over n. No success with python. The npTDMS lib has a function to read in, but it seems to attempt to read in the entire file which is always significantly larger than the available RAM.
Has anyone come across a way to incrementally read in TDMS using python?
(2,951 Views)
I haven't tried this, and I doubt it's the best way, but the TDMS file format is well documented.
The details can be found here: TDMS File Format Internal Structure, and an overview (with marketing blah): The NI TDMS File Format.
If you can't get whatever Python library is available to work, you could manually read the binary data file according to the formatting instructions...
GCentral
(2,905 Views)
