Incorrect Multiply Result?
I'm doing the following, and received the wrong value. Is there something I'm missing?
(5,110 Views)
Why is this incorrect?
anything x 0 = 0 and -0 = 0
(5,095 Views)
To prove that -0 is equal to 0, add an increment by 1 after the multiply and before your indicator.  The math is correct, it may just look wonky.
(5,084 Views)
I mean it makes sense. The reason why I ask is because problem arises when I try to convert this is an string which now becomes "-0". Doing any comparisons fails immediately. Is there a reason why LV does this, rather than follow -1 * 0 = 0?
(5,069 Views)
Accepted by topic author Tom321
Well, there is a sign bit in the IEEE754 specification.  When multiplying, the two sign bits should just be XORed.  -1 has a sign of 1 (negative) while 0 has a sign of 0 (positive).  XOR the values and you get 1 (negative).  This results in -0.
For additional reading: Signed zero
(5,062 Views)
Define "fail". If you do the comparison on the numerics, you can see that -0 and 0 are equal as expected.
(4,974 Views)
Tom321 did sort of define it.  He stated that he converts to a string and then does comparisons.
(4,916 Views)
