Incompatible image type
I'm getting an imcompatible image type when using Setup Pattern 2, Learn Pattern 2, and Match Pattern 2. I understand that this error is thrown when the bit depths of the image template and searchable image are different, but in my case, everybody is a 16bit image.
Any suggestions? Attached is an image of my setup.  You can see from the probes that everybody is a 16bit image.
(2,796 Views)
Whoops, moved to Vision forum
(2,763 Views)
