Include timestamp FIFO high data rate
Good afternoon,
I'm working on a project where the system is implemented in a cRIO-9068 with 8 modules using Labview2019.
I need to acquire different modules at different data rate, at 10 kHz and 100 Hz using a FIFO. I set the acquisition with the TDMS and it is working at high data rate but the problem is related to the inclusion of a timestamp of each data acquired. I tried different methods but it seems as if the file cannot write time at the same speed as it writes data.
I can't use the function daqmx because it is not supported by my cRIO.
Thank you in advance.
(1,062 Views)
I recommend NI CompactRIO Waveform Reference Library
https://tmesystems.net/
(1,012 Views)
Thanks for the answer! I'll have a look to the new functions.
By the way I have been able to add the starting moment of the acquisition with the wf start time in the tdms format. Do you know if there is a way to add also the wf end time? This would be a kind of work-around solution because I know the acquisition rate.
Thank you.
(989 Views)
Use the waveform data type to include t0, dt and other attributes like the channel name. This replaces your "to dynamic data".
This will set the wf_start_time and wf_increment in the TDMS file.(See here: TDMS File Format Internal Structure#Predefined Properties)
The waveform attributes will be written as TDMS properties.
write waveform to tdmswrite waveform to tdms
(973 Views)
Thank you.
You can't define end time directly. The end time is t0 + dt*([number of elements in Y] - 1). See Using the Waveform Data Type in LabVIEW to understand more about this data type.
(968 Views)
