Include Labview Runtime Dependencies in Linux Build
Is there a way to include the labview runtime dependencies in a linux build so that labview runtime does not have to be installed manually on any computer that wants to run the executable software?
(4,005 Views)
The LabVIEW runtime has been a separate install ever since about version 5 or 5.1. That is for all OS's. So, the answer is no.
(3,997 Views)
Keenan,
Perhaps I may be misinterpreting your question and Dennis' response.. So please correct me if I am wrong. But are you asking if there is a way to include the LabVIEW Run-Time Engine into your Application Installer from your executable?
If so, then yes, this is possible. Please refer to this article that describes how to include the Run-Time Engine into the Application Builder's Installer.
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(3,984 Views)
There is no create installer option for Linux and I understood the question to how to include the runtime with the exe created when you do a build.
(3,975 Views)
Yes I realize that there is no intaller option for linux. I was wondering if there was a way to include the required run time dependency when a build is created.
(3,967 Views)
You can see this Idea Exchange thread.
(3,962 Views)
