InRangeCompareFunction
the yellow indicates how the signal should be
like how the green should follow the white at that point which is marked wrong
Message 11 of 24
(2,423 Views)
So if I understand you do not want the green to follow the white unless it is greater than red. Then when the white goes below the red you want the green to follow the white?
Tim
GHSP
Message 12 of 24
(2,419 Views)
Yes
Exactly
Message 13 of 24
(2,417 Views)
Then how do you know when the green should not follow the white when the signal starts going up again or is this a one time up and dnow thing?
Do you understand the question?
Tim
GHSP
Message 14 of 24
(2,415 Views)
No, its not a one time up and down
Good question.
Well you have already done it in the attached VI
This is where may be the program gets complex.
At the end of the cylce i.e. When white gets to the value zero Again, you have to restart the cycle. But when white is above the 1, and when white < red, then green should follow white
Message 15 of 24
(2,410 Views)
so you are sure that the value will always hit 0 going down and 1 going up?
Tim
GHSP
Message 16 of 24
(2,406 Views)
Sorry for confusing you
 i didnot mean to say
"But when white is above the 1"
Message 17 of 24
(2,405 Views)
yes i am sure that the value will hit 0 and 1
Message 18 of 24
(2,404 Views)
Give me a few minutes I will see waht I can do for you.
Tim
GHSP
Message 19 of 24
(2,396 Views)
thanks
Message 20 of 24
(2,392 Views)
