In which pallette I can find " Write to Spreadsheet File.vi" in Labview 2015?
I am getting signal from a sensor by DAQ device. After processing it, I have three columns. Time/Date - signal average - Standard deviation
I have trouble writing it to a excel file. I used "write to measurement file.vi" but I do not know how to add columns in it and there is no place for labeling (giving a title for the column). Also when I open my excel file, the Time/Date is like ####### .
When I open my older files with 2015 labview I see a big red X inside the icon of "write to measurement file.vi". I remember in 2012 it was not like that. Thank you for your help.
(4,445 Views)
Accepted by topic author SilasIII
No need to create a new topic for essentially the same question. Use the Write Delimited Spreadsheet VI for the same functonality.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,443 Views)
