In range and coerce binary operation
How do I implment the "in range and coerce" function with binary operation?  I want to do that to make my fpga code more efficient.
(2,888 Views)
Please explain what you mean by "binary operation", that could mean many different things.
(2,883 Views)
What exactly do you mean by "binary operation"?  I am assuming you are dealing with integers here to make life simple.
The In Range portion is just a simple Less Than and a More Than with an AND ( x < UL && x > LL).  The Coerce portion would likely be best done with Select nodes based on the Less Than and the More Than comparisons.
(2,871 Views)
Bit and logic operations.  For example, if I want to change a subvi that is checking is the input greater or equal to 8, I would convert the input into a binary array, and do a logical AND to all bits higher than the 4th bit.  I am wondering is there a similar method for in range and coerce.  I think I can make the method that I mention above works for this case as well, but want to know is there a better way.
(2,844 Views)
