In labview 64bit, Use PostLVUserEvent with user data cluster, unhandled exception occured.
My labview is Labview 2009 64 bit, I use PostLVUserEvent to post message with cluster data to labview. The following is  the struct in dll:
typedef struct {
    int32 dimSize;
    uInt8 elt[1];
} TD1DINT8;
typedef TD1DINT8 **TD1DINT8Hdl;
typedef struct{
   int32       interruptSource;
   TD1DINT8Hdl portData;
}DIInterruptData, *PDIInterruptData, **HDIInterruptData;
In labview, the DIInterruptData corresponds to a cluster, in which there are a int32 integer and a uint8 array.
It works well in labview 32bit. But in labview 64bit, unhanlded exception occured. why?
(2,413 Views)
Dear,
         You posted same thing twice.
Thanks as kudos only:)
(2,411 Views)
Hi Danil,
when complaining about double-posts one should provide a link to the other thread to guide other users...
(2,407 Views)
