In Range and Coerce
I am having some inconsistencies with the In range and coerce function.  I realize the problems with trying to representing numbers exactly in binary format.
In my main program I get one result, and when I created a test case in a different vi, I get the opposite result.
How can I account for this in my code?
Attached are pictures of both VIs.
(3,662 Views)
You simply need to increase your tolerance to a level where the results are as desired. 😄
Message Edited by altenbach on 05-17-2006 12:34 PM
(3,642 Views)
That's part of the problem, I can't.
We are testing whether a measurement is inside a specific interval to determine whether the measurement is in tolerance.
So we can't widen that interval.
(3,636 Views)
You only need to widen it by a hair to take care of binary rounding. e.g. try to add 1e-12 to your tolerance. It won't make any real difference to the result.
(3,620 Views)
Good idea.  I'll give it a try.
thanks for the suggestion
(3,612 Views)
Nice suggestion, it worked great!!! Smiley Happy Smiley Happy Smiley Happy
Thanks again
(3,589 Views)
