In Place Index and Replace
This is again one of those things that could be an Ideas Exchange to some, and a bug to others.  If I have a 1D array, and I use the Index function it starts at index 0 without having to wire anything to the index terminal.  If I use an In Place Element Structure and choose the Index and Replace Array I get a broken arrow if I leave the index terminal un wired.
Also If I wire an index with a value of 5, when I expand it down I expect it to index element 6, and 7, and 8 and continue for the size of the index function.  Here again is where the native Index function behaves differently from the IPE index and replace.  Is this a bug?  Is this an Idea of how the IPE should work?
(3,207 Views)
I would expect the IPE to behave exactly like the index function. Didn't even realize it doesn't!
Kudos for the idea, Hooovah.
(3,205 Views)
I'd consider that a bug, the only difference should be that it works in the same memory, nothing else.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,189 Views)
Accepted by topic author Hooovahh
It was already suggested here - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Provide-good-defaults-for-unwired-indices-of-the-array...
And here (which discusses a slightly different behavior with >1D arrays) - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-unwired-index-for-quot-Array-Index-Replace-Eleme...
We also had a discussion which touched on the topic of how the IPES behaves here - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Set-index-inputs-on-LVOOP-array-element-accessors-to-R...
___________________
Try to take over the world!
(3,185 Views)
When I posted this topic the forum made me search (as is expected) but in the forums nothing came up.  Glad to see great minds are already thinking about this.
(3,179 Views)
Got confronted with this issue today using LV2014. The 2015 beta version was annouced not long ago, hope the change will be made in this version.
Ben64
(3,038 Views)
