In Max, click Test Panel - Get Executable version (7.1.1) doesn't match resource file (7.1)
I haven't used LabVIEW for a while.
I plugged in a USB-6251 and ran Measurment and Automation explorer and saw that the USB-6251 was in the NI-DAQmx Device and was green.
I clicked on the Test Panels button and got a window with the message:
When I clicked OK  MAX was locked up.
I found this:
http://digital.ni.com/public.nsf/websearch/680E61A4D02158A186256F7A0073C228?OpenDocument
which told me to repair the LabVIEW Runtime thingy.  I did that and it's still broken.
My MAX version is 4.2.0.3001
I assume that's a pretty old version but I would have thought it should have been updated when I upgraded to LabVIEW 8.2.1.  But I don't see a MAX folder in the 8.2.1 install.
(2,972 Views)
Did you run the Device Driver CD after installing LV 8.2?
(2,957 Views)
I thought I had replied to this but somehow it didn't get there.  In answer to the question about running the device driver CD after installing LV 8.2 I don't know the answer.
Anyway I installed LV8.6.1 and now it goes into test panels OK so I should be able to progress.
(2,929 Views)
