In MAX, my configuration tree has no "Devices and Interfaces" item. How do I get that?
My tree is shown in the attached PNG file, which is basically this:
My System
    Software
Remote Systems
Message 1 of 11
(6,251 Views)
Where did you download your MAX?  What type of device would you like to connect to?
Message 2 of 11
(6,242 Views)
I downloaded the 30-day trial of LabVIEW, and MAX appeared. Maybe I got MAX lite. 🙂
Message 3 of 11
(6,236 Views)
You can download this for MAX.  This copy works with serial device.
http://joule.ni.com/nidu/cds/view/p/id/2316/lang/en
Message 4 of 11
(6,218 Views)
You only install NI-Serial if you have a National Instrument serial interface product. The poster did not say anything about serial, so why are you telling them to install that software?
To poster: read this: http://digital.ni.com/public.nsf/allkb/D1F1D3FC80E4FFDF86256B410059DE31
Message 5 of 11
(6,213 Views)
I use serial device a lot, so I woudl install the NI-Serial.  If you install the NI-Serial, it would give you the latest MAX, right?  I believe that latest MAX is what he wants, and having serial is probably not a bad idea.  Nevertheless, it was just a suggestion.
Message 6 of 11
(6,200 Views)
As I pointed out, NI-Serial is only required if you have a National Instruments Serial Interface product. If you have built-in serial ports then you do NOT need NI-Serial. MAX is installed with LabVIEW. You do NOT need to install NI-Serial, and to say "serial is probably not a bad idea" is simply ludicrous. Especially in light of the fact that we don't even know what devices and interfaces the user is trying to access. Smiley Surprised
Message 7 of 11
(6,191 Views)
Well, the quick answer to why you don't have a "Devices and Interfaces" entry is that you don't have any hardware drivers installed so MAX couldn't populate Devices and Interfaces.  Once you install the hardware driver that you nee, this section will be added.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 8 of 11
(6,188 Views)
The same problem happened to me. I want to connect Tektronix 3054B to my PC via ethernet, and I have already installed the driver for this device according to the method on the webpage http://zone.ni.com/wv/app/doc/p/id/wv-1668. But I still cannot find the "Devices and Interfaces" item in MAX. Attched is the picture of the window.
Message 9 of 11
(6,085 Views)
Hey muhe889,
If you are connecting the device over ethernet, it should appear under Remote Systems, not My System. Check there and let me know if you still can't see it. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
Message 10 of 11
(6,051 Views)
