In Labview 5.0, How do I disable closing VI with 'close window' button available in top-right corner of window ?
(3,054 Views)
Have a look at the "VI setup...windows options" (right-click on the icon in the top right).
Instead of disabling the close button, you could just not show the window title bar so there is no close button visible.
LabVIEW 5.0 is ancient history. Have you considered upgrading?
Newer versions have many more options available, for example you could use filter events to execute special conditional code if the close button is pressed (e.g. popup a window saying: "Please turn off machine ABC first, then try again").
(3,053 Views)
Thank you very much Mr. Altenbach for your quick reply. Your suggestion solved our problem in least efforts. Thanks once more.
About Labview upgradation, we are in the process to get the latest one(7.1). but we did not want to disturb the above program (developed in 5.0) as it is working satisfactorily.
regards
Pranav
(3,020 Views)
