I suggest to use two arrays; one for user interface holding the ON clusters,
and one for internal use holding all clusters. The diagram periodically
updates the internal array with user interface array data.
By INVISIBLE do you mean "skipped from the array" or displayed as an empty
placeholder? To hide an OFF cluster you could put in the cluster a flat
button boolean that is small and transparent when ON and large enough to
cover the whole cluster area (and other controls) when OFF.
Jean-Pierre Drolet
Scientech R&D
"mcmastal"
a écrit dans le message news:
506500000008000000281F0000-986697009000@quiq.com...
> In LabVIEW6i, is there a way to make particular elements of an array
> invisible while the others stay visible (without losing any element's
> info.)?
> I have an array of clusters. Each cluster pertains to a certain
> oscilloscope I am controlling. There is another control which
> specifies which oscilloscopes I have "on".
> If a particular oscilloscope is "on" I want its cluster to be VISIBLE
> in the array. If a particular oscilloscope is "off" I want its
> cluster to be INVISIBLE in the array.
> How can I implement this in my program without losing ANY of the
> info. in my array?
