Improving LabVIEW PDA graph speed.
Is there an easy way to improve upon the LVPDA graph speed? I am writing an application which is currently limited by the update rate of the LVPDA waveform graph indicator.
The indicator appears to render the image on screen rather than creating a pixmap first and then dumping the whole image in one go which would be much faster.
SubDH
(3,674 Views)
Do what the example programs do and decimate the array before you display it.
(3,674 Views)
hello,
did you succeeded ??? i have the same problem ...
this works very slow ...
ya
(3,674 Views)
